Cisco VSS - VSL Interfaces Down
Bruno Veras
I'm having a VSL case where I have two VSL interfaces, and it's in not-connected status. The fiber-optic cable and the GBIC transceiver have already been replaced, and yet it has not normalized.
ip_guy
Hello Bruno,
Have you checked if transceivers are compatible with equipment? Could you send configuration of Po11 and Fo1/1/4 and Fo1/2/4 interfaces? Did you configure same mode for channel-group (on/on, active/active)?
Cheers
Hello
Can you post the vsl config for each physical switch?
Kind Regards
Paul
