sfp error Nexus 3K help
nflnetwork
i'm trying to insert SFP+ transceiver but seeing the following :
Eth1/15 -- sfpErr routed full 10G 10Gbase-SR
when i run "sh int transceiver", i see ..
Ethernet1/15
transceiver is present
type is 10Gbase-SR
name is AOI
part number is A7ELSN85ADMA0684
revision is A
serial number is 65418F10254
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is 3
cisco extended id number is 4
Can anyone tell me if this transceiver is compatible or not?
Did i miss anything ?
Mark Elsen
 - Is there any additional info in  show logging , when you insert the transceiver ?
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
nazimkha
Try this
service unsupported-transceiver
where do i enter this command. are you sure it works on NX-OS ?
N3K1(config)# int e1/3
N3K1(config-if)# ?
bandwidth Set bandwidth informational parameter
beacon Disable/enable the beacon for an interface
cdp Configure CDP interface parameters
channel-group Configure port channel parameters
dampening Configures dampenning feature
delay Specify interface throughput delay
description Enter description of maximum 80 characters
duplex Enter the port duplex mode
flowcontrol Configure interface flowcontrol
ingress-mtu Set/reset ingress port mtu value
ip Configure IP features
ipv6 Configure IPv6 features
lacp Configure LACP parameters
link Configure link
lldp Configure Interface LLDP parameters
load-interval Specify interval for load calculation for an interface
logging Configure logging for interface
mac MAC
mtu Configure mtu for the port
nac Enables eou on current interface
negotiate Configure link negotiation parameters
no Negate a command or set its defaults
ntp NTP configuration
rate-limit Set packet per second rate limit
service-policy Configure service policy for an interface
shutdown Enable/disable an interface
site-of-origin Site of Origin
snmp Modify SNMP interface parameters
speed Enter the port speed
switchport Configure switchport parameters
system System-related show commands
ttag Hardware ttag timestamp
untagged Default to use for untagged packets on interface
vrf Configure VRF parameters
end Go to exec mode
exit Exit from command interpreter
pop Pop mode from stack or restore from name
push Push current mode to stack or save it under name
where Shows the cli context you are in
