Cisco VSS
John Apricena
Hello All,
I am configuring VSS between two 4500x switches, and am having difficulty. I followed the below insturctions from cisco's site, however I both times I've tried this, the standby switch continues to reboot right when it finishes booting. The below link was what I used to setup the VSS, the config begins below "Converting to a VSS".
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/15.1.2/XE_340/configuration/guide/vss.html#wp1062785
Below are the logs I get from the standby switch right before it reboots. The primary switch says it connects to it's peer, then about a second later it disconnects.
*Dec  3 14:33:45.276: %GBIC_SECURITY-4-UNSUPPORTED_GBIC_INSERTED: Unsupported transceiver inserted in port 460
*Dec  3 14:33:45.276: %C4K_CHASSIS-3-TRANSCEIVERCRCINTEGRITYCHECKFAILED: Transceiver integrity check on port 460 failed: bad crc
*Dec  3 14:33:47.330: %GBIC_SECURITY-4-UNSUPPORTED_GBIC_INSERTED: Unsupported transceiver inserted in port 461
*Dec  3 14:33:47.330: %C4K_CHASSIS-3-TRANSCEIVERCRCINTEGRITYCHECKFAILED: Transceiver integrity check on port 461 failed: bad crc
*Dec  3 14:33:49.534: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 1.
*Dec  3 14:33:51.646: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 2.
*Dec  3 14:34:05.531: %VSLP-5-VSL_UP:  Ready for control traffic
*Dec  3 14:34:09.539: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as STANDBY by VSLP
*Dec  3 14:34:47.100: %C4K_REDUNDANCY-3-COMMUNICATION: STANDBY:Communication with the peer Supervisor has been established
*Dec  3 14:35:05.453: %SPANTREE-5-EXTENDED_SYSID: STANDBY:Extended SysId enabled for type vlan
*Dec  3 14:35:06.240: %VSLP-3-VSLP_LMP_FAIL_REASON: STANDBY:Te2/1/1: Link down
*Dec  3 14:35:06.253: %VSLP-3-VSLP_LMP_FAIL_REASON: STANDBY:Te2/1/2: Link down
*Dec  3 14:35:06.253: %VSLP-2-VSL_DOWN: STANDBY:  All VSL links went down while switch is in Standby role
*Dec  3 14:35:06.254: %C4K_REDUNDANCY-3-NOT_READY_FOR_SWITCHOVER: STANDBY:The active Supervisor failed but standby supervisor cannot initiate Switchover activity. Resetting standby Supervisor.
*Dec  3 14:35:06.386: %RF-5-RF_RELOAD: STANDBY:Self Reload. Reason: Standby not ready for switchover
*Dec  3 14:35:06.414: %SYS-2-NOBLOCK: STANDBY:sleep for with blocking disabled. -Process= "Cat4k Mgmt LoPri", ipl= 0, pid= 86
-Traceback= 1#251bc17810f5fe5cfe9c51cc9cacd46b  :12252000+2699F4C :12252000+269A310 :12252000+1F1B55C :12252000+38D4044 :12252000+F90A18 :12252000+3F7AB28 :12252000+3F8A7C4 :12252000+F90C78 :12252000+1F1ED44 :12252000+FB3100 :12252000+6088234 :12252000+1BD80D8 :12252000+6088088 :12252000+FA3294 :12252000+FDA144 :12252000+FDA220
*Dec  3 14:35:06.418: %SPILIB-3-PL_NO_SUSPEND_ERRMSG: STANDBY:SPI process suspend not allowed
-Traceback= 1#251bc17810f5fe5cfe9c51cc9cacd46b  :12252000+2699F4C :12252000+269A310 spilib:4D53B000+30380 spilib:4D53B000+11BF0 spilib:4D53B000+12038 shutdown:4CB54000+13F40 shutdown:4CB54000+9CCC :12252000+1BFB1CC :12252000+1BEB540 :12252000+1F1ED44 :12252000+FB3100 :12252000+6088234 :12252000+1BD80D8 :12252000+6088088 :12252000+FA3294 :12252000+FDA144
*Dec  3 14:35:06.493: %SYS-5-RELOAD: STANDBY:Reload requested by Platform redundancy manager. Reload Reason: Standby not ready for switchover.Please stand by while rebooting the system...
                              Restarting system.
Any help or advice would be greatly appreciated.
John
I suspect that my be the issue. Do you have any Cisco GBICs you can try it with ?
Jon
5 Replies 5
Jon Marshall
John
Right before the failure there are transceiver error messages for two ports. Are you using Cisco supported transceivers and could these ports be the two ports used in the VSL link ?
If so that may be your problem.
Jon
Hi John,
Thanks for the quick response. You are correct I am not using Cisco SFPs. I am using a third party brand. For VSS to work do I need to have Cisco transceivers?
Actually the switch is not recognising your GBIC and the link between the two chassis is going down which leads to VSS failure.
John
Jon
Hey Jon,
The Cisco GBICs resolved the issue. Thanks again!.
