Cisco Wake on LAN max subnets
Mokhalil82
Level 4
Level 4
I am currently implementing WOL on a network to enable the WOL server to wake up remote PCs and Wyse terminals on different subnets. On the server VLAN I need to configure an IP helper to the broadcast address on the destination subnets. I have over 30 different subnets.
Am I right in assuming that there will be a limit to the amount of IP helpers or ip dhcp relays I can configure.
If so, is there a work around as it seems this could be a limitation to my WOL setup
I hope this link helps,it only has 4 Vlans but it is scalable
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/91672-catl3-wol-vlans.html
regards
Richard.
