Cisco WCCP (multicast method ) with Bluecoat Implementation
vishal_2007
hi
Cisco WCCP with Bluecoat Implementation  . during implemetation multicast packet not flow to other vlan interface.
few observation .
  • Cisco wccp with bluecoat proxy ( Multicast method )  - Multicast IP # 224.1.1.103 , Group 11, dense-mode
  • Same Vlan  its working ( user and Proxy SG )
  • Different Vlan not working ( user Vlan 10 and server Vlan 20 )
sample configuration :
ip multicast-routing
ip wccp 11 group-address 224.1.1.103 redirect-list 103
sh ip access-lists 103
Extended IP access list 103
    40 permit tcp 10.10.10.0 0.0.0.31 any eq 443
    50 permit tcp 10.10.10.0 0.0.0.31 any eq www
    60 permit tcp 10.10.10.0 0.0.0.31 any eq ftp
    70 deny ip any any
interface Vlan10 description "AP_User_Range"
 ip address 10.10.10.0 255.255.255.0
 ip helper-address 10.10.20.100
 ip wccp 11 redirect in
 ip wccp 11 group-listen
 ip pim dense-mode
8 Replies 8
Jon Marshall
With WCCP the traffic from the clients is not multicast so you do not need to enable multicast routing because there is no mutlicast traffic to route. The client traffic is normal unicast http/https etc. traffic.
The multicast group is used for the switch to communicate with the proxy server(s) and it does not need to be routed.
So you should remove the multicast routing and PIM configuration.
The "ip wccp 11 group-listen" command should be removed from the client vlan  SVI and added to the SVI for the vlan the proxy server is in.
Jon
thanks for update .Jon
below configuration is correct ? , any changes required
interface Vlan10 ( client Vlan )
int vlan 20 ( server Vlan )
Dear Jon,
After changes the WCCP Command  ,still  WCCP not working
but  both client and Proxy Same VLAN its working fine with Multicast mode
interface Vlan10
 ip address 10.10.10.10 255.255.255.0
 ip helper-address 10.10.10.100
interface Vlan20
 description PROXY_WAN_VLAN
 ip address 10.10.20.10 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
    40 permit tcp 10.10.10.0 0.0.0.255 any eq 443
    50 permit tcp 10.10.10.0 0.0.0.255 any eq www
    60 permit tcp 10.10.10.0 0.0.0.255 any eq ftp
    70 deny ip any any
sh ip wccp
Global WCCP information:
    Router information:
        Router Identifier:                   -not yet determined-
        Protocol Version:                    2.0
    Service Identifier: 11
        Number of Service Group Clients:     0
        Number of Service Group Routers:     0
        Total Packets s/w Redirected:        0
          Process:                           0
          CEF:                               0
        Service mode:                        Open
        Service Access-list:                 -none-
        Total Packets Dropped Closed:        0
        Redirect access-list:                103
        Total Packets Denied Redirect:       0
        Total Packets Unassigned:            0
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total GRE Bypassed Packets Received: 0
Have you confiured the multicast address on the proxy server ?
Jon
Yes, running with multicast method
From client vlan traffic flow to 2 or more blue coat proxy server, so we implementing multicast mode.
after removed command not working .
please find the bluecoat sample setting
Looking at the outputs you provided it doesn't look like the switch is seeing any proxy servers.
Have you tried using the unicast method just to rule out any other potential issues with switch and proxy servers ?
Jon
we tried unicast method also not working , but same vlan -its working fine
in WCCP - not getting the router identifier
Switch#sh ip wccp
    Router information:
 l
interface Vlan10
end
Switch#sh run int vl 20
Building configuration...
Current configuration : 112 bytes
interface Vlan20
 ip address 20.20.20.1 255.255.255.0
 ip pim sparse-dense-mode
end
Switch#sh run | in wccp
ip wccp 11 group-address 10.10.10.10 redirect-list 103
can you share any working configuration (multicast )
If unicast is not working either then it suggests a more fundamental problem.
Try a very basic unicast configuration ie.
ip wccp redirect-list 103
int vlan 10
and that's it. Remove all other WCCP configuration from the switch.
And then configure your proxy server with the IP address of the switch and test.
Jon
