How to design for physical layer redundancy
michaelngai
Hi All,
Seeking a bit of advice here.
Have a requirement to design a flat L2 network for a small manufacturing plant with different buildings.  One of the requirement is to have physical layer redundancy, where there is a chance people would dig up the ground and cut off entire conduits.  Thus the requirement of having multiple conduits between buildings.
This means a lot of L2 loops and daisy chaining of selected buildings (switch).
Is there a cleaner design to this rather than relying purely on STP to take care of things?  Is there anything in particular that we should be aware of?
At this stage, I can see roughly 14 switches in the entire design, scattered across multiple buildings.
Thanks in advance for any tips / advice.
Elton Babcock
What kind of switches will you have available to you or what is the budget on this?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
How clean your design might be would depend on not just the count of your switches, but what's possible for physical interconnections.
Besides STP (would recommend RSTP or MST), some switches support REP and some Cisco switches support Flex Links.  There's also Etherchannel and switch stacking (e.g. 2960S, 2960X).
What's technologies you might use depend on your switches' features.  Which might be best, again, depends on what you physical topology might support.
