cisco works 2k
singh.ashish
hi expertise,
m using cisco works 2k, the problem is its getting very slow during login time as well as browsing time. what could be the problem.
thanks & rgds..
Ashish Singh
5 Replies 5
leighharrison
Level 7
Level 7
Hi there,
Check the spec of the machine it's running on. There is a lot of java running on these programs and you might need to beef up a little.
Hope that helps,
LH
Please rate all posts
Thanks 4 Reply,
i hve very higher end server so i dont think it could be a problem. when m accessing locally (on server itself) getting very slow takes lot of time.
rgds.
ashish Singh
Have you got the right/latest version of java ?
LH
Ya i had,But the thing is CD one fifth edition support jre 1.3.1.
thanks & rgds...
Ashish singh
glen.grant
Is ciscoworks directly on your network? We have found that CW2K works very poorly if it has to run thru any kind of firewalls at all . It becomes next to unusuable when going thru firewalls. Also look for things like speed/duplex mismatches between the server and the switch it is attached to.
