cisco WS-C2950-24 Last reset from system-reset
Scott O'Brien
Hi All,
Does anyone know what " Last reset from system-reset " means?
Is this becouse of a power failure or someone reloading the switch?
Leo Laohoo
"reset" means someone issued the "reload" command.
Leo Laohoo
Thanks, im guessing there is no way to check who logged in unless you go via the radius server log?
just out of curiosity what would the switch show if the power was cut?
if you cut the power and than turn on the switch again, it will show this in sh ver:
Last reset from power-on
