Cisco WS-C4948E - four 1/10 Gigabit Ethernet uplink
evmartinez1
Hello Community,
I have this question about the implementation of a Cisco 4948E
It's possible to mix on a cisco WS-C4948E a 1G LX port and one 10G SR port, and this can operate properly?
I appreciate your help.
reliability 254/255, txload 1/255, rxload 1/255
Keep an eye out for stability &/or line errors.  The item above in RED should never be any value other than "255".  This means there is a potential line error.
6 Replies 6
Leo Laohoo
What do you mean by "mix".
Connect a 1G LX port and a 10G SR port  and both operate at the same time, for different services.
Thanks.
Connect both ports together?  Not possible and it won't work.
It works, like a champ.
#show inter te 1/51
TenGigabitEthernet1/51 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet Port, address is bc16.65fb.2fb2 (bia bc16.65fb.2fb2)
Description: TRUNK
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-SR
#show inter te 1/52
TenGigabitEthernet1/52 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet Port, address is bc16.65fb.2fb3 (bia bc16.65fb.2fb3)
Description: IXP
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLH
Thanks to everybody.
So far... it works with out problems.
Thanks.
