04-26-2020 11:12 AM - edited 04-26-2020 11:13 AM
there is two power modes in cisco 650X redundant,combined
my question is when power mode in redundant what (Status Status State ) must to be ?
sho power
system power redundancy mode = redundant
system power redundancy operationally = non-redundant
system power total = 2669.10 Watts (63.55 Amps @ 42V)
system power used = 1204.14 Watts (28.67 Amps @ 42V)
system power available = 1464.96 Watts (34.88 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-2700-AC/4 1319.22 31.41 - - off
2 PWR-2700-AC/4 2669.10 63.55 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 FAN-MOD-4HS 96.18 2.29 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 VS-S720-10G 338.10 8.05 338.10 8.05 on on
2 WS-X6708-10GE 444.36 10.58 444.36 10.58 on on
3 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit = 4000.08 Watts (95.24 Amps @ 42V)
system auxiliary connector power limit = 4000.08 Watts (95.24 Amps @ 42V)
system primary power used = 1204.14 Watts (28.67 Amps @ 42V)
system auxiliary power used = 0 Watt
Is there any issue in show power command above ?
or it's normal to be "off" state in "redundant" mode
04-27-2020 12:37 AM
- It indicates that power supply 1 is off which probably is not intended, check it's status by visiting the box and inspect the power supply status (led indicator - for example).
M.
