cisco WS-C6506-E Port-Channel 2A
arron
I was about to make some changes on one of our 6500 series switches, and I noticed there is an interface Port-Channell2A. The device shows the following port-channel’s when doing: show ip interface brief:
Port-channel1          unassigned      YES unset  up                    up
Port-channel2          unassigned      YES unset  down                  down
Port-channel2A         unassigned      YES unset  up                    up
Port-channel3          unassigned      YES unset  down                  down
Here is the output from show run int:
KG-CORE#show run int port-channel 2A
Building configuration...
Current configuration : 5 bytes
end
Current configuration : 202 bytes
interface Port-channel2
switchport
switchport trunk native vlan 4
switchport trunk allowed vlan 2,4,109,215,255
switchport mode trunk
mls qos trust cos
end
I need to add a vlan and allow access to the new vlan on port-channel1 and 2, but when looking at port-channel 2 it shows the vlan tagging I need to edit, but the port-channel is down. When looking at port-channel 2A the interface is up, but there is no configuration associated with it when doing a show run.
I wanted to see if I could clear this up before making any changes, and was curious of what might have cause this.
dhristov
hi Arron,
It means the physical interfaces in the channel are not in-synch or there are members in your LACP bundle that do not have the same config or have capabilities mismatch.
If the inconsitency is cleared you need just to shut/no shutdown the port-channel to renegotiate the Port-channel.
Please can you add information what is the port capablities and the configuration from both sides.
show interface capabilities
show interface trunk
show etherchannel 2 summary
show etherchannel 2 detail
-Dimitar
