Ciso 2960x High CPU Usage
aheredia05
i have a cisco 2960x series switch, this has been generating high usage of cpu, this is the output of show proc cpu sort 5sec command:
CPU utilization for five seconds: 61%/27%; one minute: 61%; five minutes: 70%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 162    62838330     8258259       7609 16.37% 15.80% 14.94%   0 Hulc LED Proces        s
 127     1722756     4676416        368  1.55%  1.55%  1.62%   0 hpm main proces        s
  60      407992    11454431         35  0.77%  0.65%  0.85%   0 Net Input
 207        5197       81111         64  0.35%  0.05%  0.01%   0 IP Input
 168         603         895        673  0.23%  0.09%  0.05%   6 SSH Process
  92       98568    15203497          6  0.17%  0.12%  0.14%   0 RedEarth Rx Man        a
  91      104838    15200378          6  0.17%  0.10%  0.11%   0 RedEarth Tx Man        a
i do not know why hulc led proces it is using too much cpu, and the 61%/27% it is too much time in interrupt time.
sorry for my english.
regards
rakeshvelagala
Level 3
Level 3
You may be hitting the below bug
Hulc LED Process uses 10-15% CPU on Catalyst 2960/2960S 24 or 48-port switch.
Conditions:
The CPU utilization for Hulc LED Process will be in the 10-15% range for the
following switch models.
* WS-C2960-48PST-L
* WS-C2960-24LC-S
* WS-C2960-24PC-S
* WS-C2960-48PST-S
* WS-C2960S-48TS-S
* WS-C2960S-24TS-S
* WS-C2960S-24TS-L
* WS-C2960S-48TS-L
The is seen in 12.2(50)SE03 or later releases.
Workaround:
This is an expected behavior and there is no workaround.
Further Problem Description:
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD)
detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
Customer Visible
Was the description about this Bug Helpful?
(7)
Last Modified:
May 6,2015
Status:
Terminated
Severity:
3 Moderate
Product:
Cisco Catalyst 2960 Series Switches
Support Cases:
204
Known Affected Releases:
(1)
12.2(50)SE3
Known Fixed Releases:
(0)
No release planned to fix this bug
rakeshvelagala
Level 3
Level 3
Conditions:
* WS-C2960-48PST-L
* WS-C2960-24LC-S
* WS-C2960-24PC-S
* WS-C2960-48PST-S
* WS-C2960S-48TS-S
* WS-C2960S-24TS-S
* WS-C2960S-24TS-L
* WS-C2960S-48TS-L
Workaround:
detected
- Update Fan status
Customer Visible
(7)
Last Modified:
May 6,2015
Status:
Terminated
Severity:
3 Moderate
Product:
Support Cases:
204
(1)
12.2(50)SE3
(0)
hi rakesh velagala,
thanks for your rapid response, i guess i have to wait untill cisco fixes the bug.
sorry for my bad english.
regards.
