Class-map inspect problem
mocah
Level 2
Level 2
Is it possible to configure "class-map type inspect" with loaded PDLM files. I have uploaded PDLM files for ednokey and bittorent, but I can not see protocols in insect class-map.
Router#sh ip nbar pdlm
The following PDLMs have been loaded :
flash://edonkey.pdlm
flash://bittorrent.pdlm
Router#sh ip nbar port-map
port-map bittorrent tcp 6881 6882 6883 6884 6885 6886 6887 6888 6889
port-map edonkey tcp 4662
When I try using this pdlm in class-map bittorent and eDonkey are not present:
Router(config)#class-map type inspect match-all p2p-test-cmap
Router(config-cmap)#match pro
Router(config-cmap)#match protocol b?
bgp biff bootpc bootps
Router(config-cmap)#match protocol e?
echo entrust-svc-hdlr entrust-svcs exec
Router is Cisco 871 image: C870-ADVIPSERVICESK9-M), Version 12.4(9)T1
sbilgi
Level 11
Level 11
Configuring Modular Policy Framework consists of four tasks:
1. Identify the Layer 3 and 4 traffic to which you want to apply actions using the class-map or class-map type management command.
2. (Application inspection only) Define special actions for application inspection traffic using the policy-map type inspect command.
3. Apply actions to the Layer 3 and 4 traffic using the policy-map command.
4. Activate the actions on an interface using the service-policy command.
http://www.cisco.com/en/US/products/ps6120/products_command_reference_chapter09186a008063f0f8.html#wp1718529
In 7.2 ASA software, you can do more extensive URL filtering with 'regex', 'class-map type regex', 'class-map type inspect', and 'policy-map type inspect' commands:
