Clear ACI Interface Fault After Moving APIC
I just repatched my APIC from port 1 on a leaf to port 48 on the same leaf.  I now have a persistent fault on port 1 that I don't know how to clear. I'd prefer to neither acknowledge nor ignore the fault - I'd like to clear it from the fault database.
I tried going to Fabric > Inventory > Pod 1 > [leaf] > Interfaces > Physical Interfaces > Eth1/1, right-clicking and selecting disable, then right-clicking and selecting enable, but the fault remains.
Any suggestions?
weylin
Fault Code:F0546
Severity:warning
Last Transition:2023-10-26T11:15:55.267-04:00
Lifecycle:Raised
Affected Object:topology/pod-1/node-205/sys/phys-[eth1/1]/phys
Description:Port is down, reason:sfpAbsent(connected), used by:Discovery
Type:Communications
Cause:interface-physical-down
Change Set:usage (New: discovery)
Created:2023-10-24T11:50:51.425-04:00
Code:F0546
Number of Occurrences:1
Original Severity:warning
Previous Severity:warning
Highest Severity:warning
Tarakesh Jetti
You can follow the below link that gives information about Fault code F0546
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy67242
It is highly recommended to raise a TAC case for clearing these faults from the database. When you prefer to neither acknowledge nor ignore the fault.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Thanks and regards,
Tarakesh Jetti
Customer Success Specialist - CX Team.
6 Replies 6
Tarakesh Jetti
Could you please let us know what is the APIC version that your fabric is running?
Thanks and regards,
Tarakesh Jetti
We are running 5.2(6e).
And thank you for the URL; I'll check that out.
Tarakesh Jetti
Thanks and regards,
Tarakesh Jetti
Thank you @Tarakesh Jetti! That exactly matched my conditions.  And, applying the squelching, the fault no longer appears in my system. Mahalo!
If I may ask a follow-up: is there a way to reset the "last linkflap" (as show in CLI) or "Last Link St Change" (as shown in the GUI)?  I tried "clear counter interface [interface]" but didn't seem to clear that parameter.
This link would help you.
https://community.cisco.com/t5/application-centric-infrastructure/cisco-aci-data-plane-policing-statistics/td-p/4861345
Thanks and regards,
Tarakesh Jetti
Thanks @Tarakesh Jetti .  The squelching solved my problem; and, I appreciate the understanding about the last link-flap.
