Clear ip opf process command
sarahr202
Level 7
Level 7
Hi every body.
My book says " ospf can be restarted with the clear ip ospf process command,but depending upon on circumstances,ios still may not change its ospf-RID until the next ios reload.
My question what could prevent router from changing its ospf router id even upon issuing clear ip ospf process ?
Thanks a lot
Lucien Avramov
Level 11
Level 11
i would only see a bug or a crash. In all my years of experience, I was always able to change the RID with a clear ospf process.
Really not sure why your book is mentioning this, perhaps they had in mind specific bug on certain code of IOS.
Lucien Avramov
Level 11
Level 11
In may home lab i changed the RID but "clear ip ospf" didn't work.... I had to reload the router. I don't know the reason of this but it worked only after the reload.
