Clearing interface counters
paul.tower
Community Member
Hi, I'm looking to identify the unused ports on all of our switches.
So I want to reset the statistics under "show interface summary".  I run that command, and then "clear counters" and confirm "y".  When I then run sho int sum the output is similar to previous and not what I expect which would be all zeros.  Looking at sho int the output tells me those counters were cleared but the numbers remain more or less unchanged.
Am I totally misunderstanding what clear count does?  I understand the figure is a five minute average however it seems that clearing the counter would result in clear counters period.
Is there a way to reset those statistics across the board?
Thanks in advance for any help!
pieterh
the counters you refer to are the 5-min interval counters,
clear counters clears the cumulative counters shown by
       show interface counters
and show interface counters error
Mark Elsen
  - Provide screenshot of observed output.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
pieterh
That works for me.  I show interface counters, clear them, and watch them increment.
