clearing interface counters
carl_townshend
Can anyone tell me how I can do this ?
atif.awan
Level 3
Level 3
You can use the clear counters command to do so. For example if you want to clear the counters for serial 0 you will use:
clear counters serial 0
The IOS command reference will provide you with additional information on this:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800874a1.html#wp1120239
guruprasadr
Level 7
Level 7
clear counters :
To clear the interface counters, use the clear counters command in user EXEC mode.
clear counters [type number]
Cisco 4000 Series or Cisco 7500 Series with a LAN Extender Interface
clear counters [type slot/port] [ethernet | serial]
Cisco 7200 Series and 7500 Series with a Packet over SONET Interface Processor
clear counters [type] slot/port
Cisco 7500 Series with Ports on VIP Cards
clear counters [type] slot/port-adapter/port
Guru Prasad.R
