Cluster Management Suite - Java Plug In Error
stephentaylor
Is any person able to explain and propose a solution to the following?
I have Windows XP Java Platform Standard Edition 6 version 1.6.0 (build 1.6.0_02-b06) installed and receive the following message when I enter the Cluster Management Suite via HTTP.
?Error: Version 1.6.0_02 of the JAVA plug-in version is not supported.
Install Version Version 1.3.0, 1.3.1, or 1.4 before you run CMS?.
aborole
Please use Cisco Network Assistant (free download)
http://www.cisco.com/en/US/products/ps5931/index.html
It does not depend on the system JRE and should have what you wanted from CMS
