Cluster problems
killroy
My problem is that I have one cluster in my network that dont respond to ping on the manage interface. All the vlans works. And I can see the mac addresses in the center router. I can ping within the cluster and the clustermaster can ping the router. Trace mac....works
Ive rebooted the system but nooooo.....
One thing Ive changed nativ vlan on one port to a AP1200. Im looking for a loop but Ive found nothing yet....
Dont know if thats the problem Im looking everywere.
fmeetz
Level 4
Level 4
Send us the console o/p of the following cmds:
Show logg buff 1023 from the sup's on the switches you are using. Show tech from the switches, MSFC, sup Also, a drawing of ur network topology
