Hi there,
I am trying to get CNA working on a 2960S-24PS-L
I am running CNA versionb 5.8(9) and we use tacacs for authentication.
Haven't managed to get it working. I can telnet to it using my TACACS credentials fine but CNA doesnt work.
Didnt see an option for ip http authentication tacacs or group so went with ip authentication aaa
Anyone seen this problem before?
I also tried to adding
aaa authentication enable default group DSLWG-TACACS
When I add the command above then debugs shows:
LINZJQ-03N-2C29-01#
AAA/BIND(00000026): Bind i/f
AAA/AUTHEN/LOGIN (00000026): Pick method list 'Permanent Local'
Current config:
aaa group server tacacs+ DSLWG-TACACS
server x.x.x.x
aaa authentication login CLI group DSLWG-TACACS enable
aaa authorization console
aaa authorization exec CLI group DSLWG-TACACS if-authenticated
aaa authorization commands 1 CLI group DSLWG-TACACS if-authenticated
aaa authorization commands 5 CLI group DSLWG-TACACS if-authenticated
aaa authorization commands 15 CLI group DSLWG-TACACS if-authenticated
aaa accounting exec CLI start-stop group DSLWG-TACACS
aaa accounting commands 1 default start-stop group DSLWG-TACACS
aaa accounting commands 1 CLI start-stop group DSLWG-TACACS
aaa accounting commands 5 CLI start-stop group DSLWG-TACACS
aaa accounting commands 15 default start-stop group DSLWG-TACACS
aaa accounting commands 15 CLI start-stop group DSLWG-TACACS
ip http server
ip http authentication aaa
no ip http secure-server
