10-02-2009 03:05 PM - edited 03-06-2019 07:58 AM
I know that it is possible to combine C3750 and C3750-E switches into a single stack as long as the entire stack runs on either IPBase or IPServices IOS. Given that C3750-Es can also run on "Universal" IOS image 12.2(50)SE or lower--I would assume that one would need to upgrade the C3750-E switches to either IPBase or IPServices before joining the stack. Is this a correct assessment? Any insights are greatly appreciated.
Keith
10-02-2009 03:29 PM
I know a 3750 stack can run with different feature sets on member switches, and (as you note) you can have a stack of both 3750s and 3750Es. I haven't tried the combination of both a mixed hardware and mixed feature set stack.
10-02-2009 03:55 PM
Yes you can.
However, read the release notes about mixed stack:
