Command deprecated (authentication host-mode multi-domain )
eperezb
I am currently configuring wired network authentication, but I encountered an error in one of my Switch. Do you know if it is possible to eliminate this error?
Version 15.2(4)E8
%Command deprecated (authentication host-mode multi-domain ) - use access-session instead
Yea, I understand that. Cisco is telling you they are in the process of removing that command and suggest using another command.
Likely the only ways to "eliminate" the error is to stop using that command or downgrading your IOS to a version that doesn't complain.
Eventually, in newer versions of IOS, that command will no longer be accept at all.
Joseph W. Doherty
Have you tried using the newer command, instead?
How? what is the newest command,
I currently use
(config-if)#authentication host-mode multi-domain
