Command: dot1x pae authenticator
amirovic13
I copied a configuration with tftp on switch 2960.
In each interface, the commande "dot1x pae authenticator" dosen't copied.
I precese that in some switch my command has succeed and other don't succeed.
thank you for help
Thank you fpr help
darrenj
Hey there. Before we delve into the configuration, is the switch using the same software as the device whose config you are trying to copy?
Darren
CCIE#20078
Can you show me the configuration, to copy the IOS from a switch to another ?
Thank you
