Command IP fast switching on the same interface is disabled
mahesh18
Level 6
Level 6
Hi All,
My routers interface fa0/0  connects to cable modem
sh ip int fa0/0
FastEthernet0/0 is up, line protocol is up
  Internet address is x.x.x.x/22
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is 110
  Inbound  access list is 102
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled **************************************************************
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
IT has cef and fast switching enabled.
My question is should i enable it or not   ---   IP fast switching on the same interface is disabled??
Will it make router performance better?
Mahesh
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Unlikely you need it.  Same interface fast switching applies to where the ingress and egress interface are one and the same.
Mahesh
Yes in your case Fa0/0 connecting to Cable modem and Fa0/1 connecting to LAN are definitely not same ingress and egress. Where it might come in handy is if you were doing router on a stick where traffic from a client would come in Fa0/1 and then be forwarded back out Fa0/1 to get to the destination then you would benefit from fast switching same interface.
Rick
Rick
Joseph W. Doherty
Disclaimer
Posting
Hi JosephDoherty,
Thanks for reply.
So in my  case fa0/0 connects to the Cable modem and interface fa0/1 connects to LAN.
So this shows  my ingress and egress interfaces are not same right??
Mahesh
Mahesh
Rick
Rick
Hi Rick,
Many thanks again for detail explanation.
Mahesh
