Command needs to be verified
cisco
       I would like to know whether a particular command can be executed on a particular IOS. I have gone to Cisco Feature Navigator pasted my IOS but its not showing that particular command .
i want to see if "neighbor X.X.X.X password" command can be executed , what i can see in Feature Navigator is BGP, BGP4 and all other things related to BGP ..Please help
regards
Neo
burleyman
Level 8
Level 8
Yes it would be
router1#config t
router1#(config)#router bgp -------- whatever AS number goes here
router1#(config-router)#neighbor 192.168.55.5 remote-as ---------whatever the remote AS number goes here
router1#(config-router)#neighbor 192.168.55.5 password ----------whatever the password you want goes here
router1#(config-router)#exit
Note this could cause a little more time in BGP message passing but should not affect IP packet processing. It could also cause a little higher CPU overhead in your peer routers.
Mike
podhillo
Hi Neo,
Please check if the command lookup tool helps your situation.
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do
go to cisco.com and search for 'command lookup'.
podhillo
I should have posted that link as well....thanks Podhillo
Mike
