Commands to check data transfer/data flow
TCCS TCS
Community Member
Hello Experts,
We have ESXi virtual machine environment where we have the core switch is on Cisco nexus 7000 and server subnets below.
On Core
server - 172.16.101.x. - Apps Type X
server - 172.16.102.x - Database
server - 172.16.103.x - Apps Type Y
My query - Which cisco nexus commands on core switch I can use to identify which virtual servers are communicating, data transferring and using ports on above mentioned subnets?? where do I need run these commands?
Please guide.
Georg Pauwen
I don't think there are any commands that will directly give you this information. Your best option is probably to configure a local SPAN session...
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/config/cisco_nexus7000_system-management_config_guide_8x/configuring_span.html
