Communication issue and conclusion from "Input errors, CRC"
news2010a
Level 3
Level 3
Folks, I have two switches:
4507 (port f3/2)---- 3750 (port f0/23)
All of sudden I see intefaces on 4507 f3/2 up/down. I go to 4507 and I see that the switchport f3/2 has some input errors and CRC errors. Then I see on 3750 switchport fa0/23 got way more errors. Also, output from show tech on 4507 switch showed message " Aug 19 10:37:22.549: %DTP-5-NONTRUNKPORTON: STANDBY:Port Fa3/2 has become non-trunk
Aug 19 10:41:57.180: %DTP-5-TRUNKPORTON: Port Fa3/2 has become dot1q trunk...". I imagine that such status that the port was a non-trunk was due to a bad communication (bad cable or bad switchport), correct?
Also, do you agree that based on the fact that I have way more input errors and CRC errors on switchport fa0/23 on the 3750 I can conclude that if it is a faulty switchport that would be likely be on the 3750? I will try to replace the cables and see if the problem goes away. Let me know if you have other approach in mind based on the data provided.
3750#show int
18682 packets input, 9509495 bytes, 0 no buffer
Received 18582 broadcasts (17576 multicast)
115699 input errors, 102042 CRC, 13657 frame, 0 overrun, 0 ignored
0 watchdog, 17576 multicast, 0 pause input
3750#show int f0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 2
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
4507#show int f3/2
FastEthernet3/2 is up, line protocol is down (notconnect)
Received 346732480 broadcasts (345361439 multicasts)
32 runts, 0 giants, 0 throttles
71 input errors, 39 CRC, 0 frame, 0 overrun, 0 ignored
20225802 packets output, 1643442465 bytes, 0 underruns
0 lost carrier, 0 no carrier
4507#show int f3/2 switchport
Switchport: Enabled
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Lucien Avramov
Level 10
Level 10
Your approach sounds overall correct.
Here is a useful doc for the CRC errors:
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K19375172
Lucien Avramov
Level 10
Level 10
glen.grant
Verify port settings on each match , if one end is set as auto for speed and duplex then the other end "must" be set as auto also. Sounds like a speed/duplex mismtach.
It turned out it was a cable miswired. Once I asked to rebuild and repatch cable, things worked.
Great.
That is usually most of the times the issue. If no one touches the duplex settings, it wont happen.
Glad you resolved it.
