Communication issue between 2 PCs on the same VLAN
Chad Jones
I have 2 computers that are on the same VLAN 4 which have problems communicating at times.  One PC is on SW1 (example) and the other is on SW2.
Both SW1 and SW2 are connected to a Core SW
SW1 - 4506 Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(25)EWA1, RELEASE SOFTWARE (fc1)
SW2 - 4506 Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(25)EWA1, RELEASE SOFTWARE (fc1)
Core SW - 6513 Running CatOS
WS-C6513 Software, Version NmpSW: 8.1(3)
Copyright (c) 1995-2003 by Cisco Systems
NMP S/W compiled on Oct 10 2003, 11:49:34
System Bootstrap Version: 7.7(1)
System Boot Image File is 'bootflash:cat6000-sup720k8.8-1-3.bin'
System Configuration register is 0x102
Hardware Version: 1.0  Model: WS-C6513  Serial #: TSC074603HM
PS1  Module: WS-CAC-2500W    Serial #: ART0744E0C5
PS2  Module: WS-CAC-2500W    Serial #: ART0744E09Y
Mod Port Model               Serial #    Versions
1   16   WS-X6516-GBIC       SAL0745P691 Hw : 5.5
                                         Fw : 6.3(1)
                                         Sw : 8.1(3)
2   16   WS-X6516-GBIC       SAL0745P6A4 Hw : 5.5
I can't PING PC1 (which is on SW1) from PC2 (which is on SW2) until I perform a PING from PC1.  I have added an ARP entry (stated below) but it doesn't help.
arp 172.16.4.252 00e0.8173.f9ee ARPA
arp 172.16.4.254 00e0.81b6.03e3 ARPA
Does anyone have any idea of what the issue may be?  Thanks in advance for your time.
Hi there,
can you send the configuration of the trunk between the switches?
What about the native vlan? Is that the same on both the interfaces trunking?
Alessio
SW1
interface GigabitEthernet1/1
switchport mode trunk
service-policy output autoqos-voip-policy
qos trust cos
auto qos voip trust
tx-queue 3
   bandwidth percent 33
   priority high
   shape percent 33
SW2
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
The native VLAN is VLAN 1 and below is the Port config for the 2 switches that are connecting to it.
SW1 connect to Core SW
Port      Mode         Encapsulation  Status        Native vlan
2/3      on           dot1q          trunking      1
Port      Vlans allowed on trunk
2/3      1-1005,1025-4094
Port      Vlans allowed and active in management domain
2/3      1-12,14-18,20,22,29-31,40,45,90,99-102,105-106,110,115-116,128-133,136,138,
141-142,152,156,161,200,220,250,300-301,900
Port      Vlans in spanning tree forwarding state and not pruned
SW2 Connect to Core SW
1/4      on           dot1q          trunking      1
1/4      1-1005,1025-4094
1/4      1-12,14-18,20,22,29-31,40,45,90,99-102,105-106,110,115-116,128-133,136,138,
