Compatibility between RPS 675 and router 29XX
Hello all,
Apologies if this is not the correct place to ask this question.
Does anybody knows if cisco routers 29XX are compatible with old 675 RPS equipment (PWR675-AC-RPS-N1=)?
The only think that I'm sure is that we can connect them with an RPS cable (one side 14 pin and the other 22 pin)
Thanks in advance
Joel
That's according to their documentation. RPS 2300 (replacement for RPS 675)  is the supported platform for ISR 2900s so It might work but not fully compatible.
"Redundant power on the Cisco 2900 Series is supported through the Cisco RPS 2300 Redundant Power System. You can use the Cisco RPS 2300 to provide redundant power for Cisco 2900 Series ISRs as well as Cisco Catalyst® switches"
Q. Does the Cisco RPS 2300 support all the Cisco routing and switching devices previously supported by the Cisco RPS 675?
A. Yes, the Cisco RPS 2300 is backward compatible and supports all Cisco Catalyst ® switches and Cisco integrated services routers (ISRs) that were previously supported by the Cisco RPS 675.
Keep in mind,
  • The Cisco RPS 675 has two output levels: –48 V and 12 V. The total maximum output power is 675 W.
  • The Cisco RPS 2300 has two output levels: -52 V and 12 V. The total maximum output power depends on the installed power-supply modules.
Feature
Cisco Redundant Power System 675
Cisco Redundant Power System 2300
Maximum number of switches and routers actively backed up
Modular power supplies and blower
NO
YES
Dual power supplies
NO
YES
Maximum power output
Class 3 PoE on 24 Ports
Class 2 PoE on 48 Ports
Class 3 PoE on 48 Ports
Automatic back-off
NO
Yes-for Catalyst 3750-E and 3560-E
Separate AC sources possible for switch and RPS 2300
NO
YES
http://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-systems/prod_qas0900aecd8062283b.html
http://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-systems/prod_end-of-life_notice0900aecd8062287a.html
I hope this helps. Good Luck!
5 Replies 5
Austin Sabio
Level 4
Level 4
RPS 675 is not compatible with 2900s routers. Please see attached "Cisco RPS 675 Compatibility Matrix ".
Please rate if helpful. Good Luck!
Thanks so much for this information,
But when this document was wroten the 29XX router doesn't exist... Are you sure that they're incompatible? Does anybody tried it?
Kind regards,
Joel
Keep in mind,
Feature
NO
YES
Dual power supplies
NO
YES
Automatic back-off
NO
NO
YES
You're right engineer_aus,
I have confirmed that these two items are incompatible :(
Kind regards,
Joel
Sorry for that, thanks for rating my answer.
-Aus
