Complex Network Design - Require assistance and issue with understanding "ip domain name" command.
david.lay901
Hi all,
I have a question, the ip domain name command.
Does using this command requires all cisco devices to use the same or what, I have never understood this command usage,
Does this command tells the device if:
e.g.
ping PC1
the device will ask the DNS server what is the ip of PC1
My lab is broken, some stuff work, some doesn't especially the Server, once the server was connected to the switch with the appropriate access vlans etc, the Windows Networking Profiles  -  assigns that to a domain network, which make the whole network switches etc cant reach the server.
Any ideas?
I have attached my diagram for reference.
chrihussey
My understanding is that it just tells the device what to append to the unqualified name. So if you have the "ip domain-name example.com" and you ping PC1 from the Cisco device it will ping PC1.example.com.
However, it's the "ip name-server [ip address of DNS] that tells the Cisco device where to direct the DNS query
Hope this helps
