Config-sync problem
Not applicable
I have two Nexus 9K and I wanted to configure interfaces in conf t but I got the message :
Error: Command is not mutually exclusive
So I though there was something in the switch-profile. After doing a show run switch-profile, I see the interface doesn't have any configuration in conf t and in conf sync.
So I tried to do a default interface, but the error message is still there.
Then I tried to configure it in conf sync to see what happens and it's telling me the same thing !  Command is not mutually exclusive.
So I can't configure these interfaces (eth1/3) on both Nexus whether it's config t or conf sync... even after a default interface because both modes tells me it's configured the other way. I tried some other interfaces and it works fine.
Any Idea ?
thanks
Reza Sharifi
Try "resync database" and see if it helps.
that did the trick, thanks!
Glad to help and thanks for the rating!
