Configuration between Cisco 3650 core switch and a firewall
1dilsarahm
Hi all,
I have a Cisco 3650 configured with inter-vlan routing. I need to connect to a Sophos UTM v9 firewall installed in ESXi so it can perform NAT and web filtering. How should be the configuration between Firewall and 3650 Core switch?
VLAN10,20,30 as access VLANs and I have Windows DHCP server configured in VLAN 40.
P.S - Sorry for my poor English.
Best regards,
Melanka
since your 3640 is doing the routing, all you need is configure an access port on the 3650 connecting to the Sophos. Any Vlan can be used. Here is an example:
3650
interface GigabitEthernet0/1
description Uplink to Sophos
switchport mode access
switchport access vlan 10
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.10.2
Sophos
interface connecting to 3650
ip address 192.68.10.2 255.255.255.0
3650
interface Vlan10
Sophos
Hi Georg,
Thanks for the solution. It's working now.
Best regards,
