Configuration lock due to rollback
Heinz Kern
hello,
i do have an issue C2960-LANBASEK9-M, Version 12.2(55)SE5
the configuration is locked due to the rollback-feature (configure terminal revert timer). the problem is that it seems to be stuck...it started to revert the config but was not able to finish...and now i am not able to enter the config mode anymore.
Configuration mode locked exclusively by user 'unknown' process '12' from terminal '0'. Please try later.
does anybody have an idea how to overcome the situation?
ic-s-bih-int-2#show configuration lock
Parser Configure Lock
Owner PID                        : 12
User                             : unknown
TTY                              : 0
Type                             : EXCLUSIVE
State                            : LOCKED
Class                            : ROLLBACK
Count                            : 1
Pending Requests                 : 0
User debug info                  : Rollback
Session idle state               : TRUE
No of exec cmds getting executed : 0
No of exec cmds blocked          : 0
Config wait for show completion  : FALSE
Remote ip address                : Unknown
Lock active time (in Sec)        : 2335
Lock Expiration timer (in Sec)   : 600
Richard Burts
Have you tried a reload or power cycle?
Rick
reloading is something i want to avoid. because it means business outage...
Reza Sharifi
Are you able to access the switch via console port?
Ceylott01
Too late for this specific instance now but in case anyone else is searching for an answer
From privileged exec mode you can run
clear configuration lock
[confirm]
