Configuration RSTP and PVSTP +
slandeira
We want to activate RTSP on two VLANs, 3 and 100, we are going to unite two new Alteon 2424-SSL.
Can I leave in the rest of VLANs of the switchs PVSTP +? Do as I can configure this mixed configuration? The switchs are: Catalyst 6506 With 720-3B. Catalyst WS-C3750G-48TS and Catalyst WS-C3750G-24TS
n.nandrekar
Level 4
Level 4
Hi!
You cannot run mixed mode. The spanning tree mode affects the mode of the entire chassis.
Further you cannot have pure RSTP on 6500. 6500 supports,
Ferrari(config)#spanning-tree mode ?
mst Multiple spanning tree mode
pvst Per-Vlan spanning tree mode
rapid-pvst Per-Vlan rapid spanning tree mode
So you can either run rapid-pvst, or if you dont want volans 3 & 100 to have different spanning tree instances, you can run mst and combine them in a single instance.
Niranjan
(pls rate helpful posts)
