Configure 4506 using Cisco Network Assistant
majdalani
whenever i try to connect to cisco switch 4506 using Cisco Network Assistant, i get the message unsupported device !
i have enabled : ip http server on the 4506 switch and still not able to connect to it using CNA.
i have 2950 and 2970 and able to connect and configure all of them using CNA, only having trouble with 4506 !
robert.horrigan
Level 2
Level 2
Older versions of CNA do not support 4500s series. Make sure you have CNA 5.0. When you try to add the 4506 to CNA, do a show logging on the switch. If you see an error about an unsupported web request, you'll need to upgrade your IOS version.
