Configure 6509 switch
sherman.jones
Need help with configuration of Catalyst 6509.
I need to be able to format 512 memory. Having problems with the NVRAM.
This is the error message I receive when I boot the switch up:
rommon 1 > boot
Loading image, please wait ...
 loadprog: bad file magic number: 0x0
 boot: cannot load "bootflash:"
 rommon 2 > boot disk0
 System Bootstrap, Version 8.1(3)
 Copyright (c) 1994-2004 by cisco Systems, Inc.
 Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Can't load IOS: s72033-advipservicesk9_wan-mz.122-33.SXJ3.bin
--Sherman
This is due to a bad IOS file.
share me the below from rommon
dev
The above will list the flash systems in the box.
Once you see them check you have a valid ios in any one of them. For example
dir sup-bootdisk:
If the above shows the ios
boot sup-bootdisk:<IOS file>
If any of these is not helping, Try to copy the same IOS to another flash card(use a card from any other switch ) and boot it.
Thanks for your help:
Here is contents of dev:
rommon 5 > dev
devices in device table:
id                   name
bootflash:      boot flash
disk0:            PCMCIA disk 0
disk1:           PCMCIA disk  1
eprom:        eprom
How can I copy IOS to flash card?
Answer:- Remove the card from this sup, Insert it on any other Sup module if you have and format once and then copy the image from bootflash to the disk0.
ex:- sw#copy bootflash;<image file> disk0:
Inayath
