06-23-2015 06:10 PM - edited 03-08-2019 12:40 AM
HI Any one can confirm the issue fo r me ? I connected Nexus7K with switch3650 by fiber. I configured it as trunk and channel-port. but "show interface status" shows "suspend--" I am not sure if we should use vPC to connect the two device. After I removed channel-port, the connection began to work. Thank you
06-23-2015 06:54 PM
Hey showipinterface,
You may be hitting the following bug.
Symptom:
When forming LACP port-channel, the port channel does not come up. The interface goes to suspended state stating the following: 'Suspended: No LACP PDUs.'
Conditions:
One of the following configured:
Globally: vlan dot1q tag native
Per Interface: switchport trunk native vlan
Workaround:
Set the configuration above to it's default value on both sides of the link.
Further Problem Description:
| Known Fixed Releases: | (36) |
06-23-2015 07:55 PM
Thank you so much for your reply
Can you tell where you got the below info? I would like to review its original message. Thank you
"Workaround:
In the below document, it said :
"Workaround : This issue is resolved. " but it did not say how to resolve it
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/release/notes/62_nx-os_release_note.html
06-23-2015 08:11 PM
