Configure command not working on Catalyst 2960L Smart Managed
 I'm trying to enter the configure mode from the console port but I'm getting unrecognized command when using the "Configure" command from the # enable mode.
If this command doesn't work then how can I configure REP or IGMP? The web UI doesn't seem to have any of those settings.
5 Replies 5
Mark Elsen
 - What happens if you type conf t ?
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi, this is what I get.
M364-Z1-M0#conf t
% Invalid input detected at '^' marker.
When I hit the ? to see what commands are available, configure is not even listed. Is it somehow restricted and we need a command to enable it??
M364-Z1-M0#?
Exec commands:
<1-99> Session number to resume
access-enable Create a temporary Access-List entry
access-profile Apply user-profile to interface
access-template Create a temporary Access-List entry
archive manage archive files
authentication Authentication options for eEdge
beep Blocks Extensible Exchange Protocol commands
bulkstat Bulkstat exec commands
calendar Manage the hardware calendar
call-home Call-Home commands
cd Change current directory
clear Reset functions
clock Manage the system clock
cns CNS agents
connect Open a terminal connection
copy Copy from one file to another
crypto Encryption related commands.
debug Debugging functions (see also 'undebug')
delete Delete a file
device device classifier
diagnostic Diagnostic commands
dir List files on a filesystem
disable Turn off privileged commands
disconnect Disconnect an existing network connection
do-exec Mode-independent "do-exec" prefix support
dot1x IEEE 802.1X Exec Commands
eap EAP Exec Commands
enable Turn on privileged commands
erase Erase a filesystem
exit Exit from the EXEC
format Format a filesystem
help Description of the interactive help system
if-mgr IF-MGR operations
ip Global IP commands
lock Lock the terminal
logging Handles logging operations
login Log in as a particular user
logout Exit from the EXEC
macro Exec level macro commands
mkdir Create new directory
monitor Monitoring different system events
more Display the contents of a file
name-connection Name an existing network connection
no Disable debugging functions
ping Send echo messages
pnpa PnP agent
port-channel lag auto persistent
pwd Display current working directory
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
rep Resilient Ethernet Protocol Exec Commands
resume Resume an active network connection
--More--
 - What is the output of the command show privilege ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Could it be because of the LAN LITE license?
Below are outputs from sh privilege, version and license command;
Thank you.
Hi there, the output is this:
M364-Z1-M0#sh privilege
Current privilege level is 15
This is the output of "sh ver" and "sh license right-to-use"
M364-Z1-M0#sh ver
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(7)E0a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 12-Apr-19 03:48 by prod_rel_team
ROM: Bootstrap program is C2960L boot loader
BOOTLDR: C2960L Boot Loader (C2960L-HBOOT-M) Version 15.2(6r)E1, RELEASE SOFTWARE (fc1)
M364-Z1-M0 uptime is 20 hours, 15 minutes
System restarted at 15:29:29 EST Sat Feb 29 2020
System image file is "flash:c2960l-universalk9-mz.152-7.E0a/c2960l-universalk9-mz.152-7.E0a.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960L-SM-24TS (Marvell PJ4B (584) v7 (Rev 2)) processor (revision A0) with 524288K bytes of memory.
Processor board ID FCW2248B5U2
Last reset from Reload
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 70:C9:C6:F1:F1:00
Motherboard assembly number : U58O342T34
Power supply part number : 341-100559-01
Motherboard serial number : FOC22467BQH
Power supply serial number : DCG222814WK
Model revision number : A0
Motherboard revision number : 01
Model number : WS-C2960L-SM-24TS
System serial number :
Top Assembly Part Number : 74-122238-01
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : CMM3Y00ARA
Hardware Board Revision Number : 0x03
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960L-SM-24TS 15.2(7)E0a C2960L-UNIVERSALK9-M
M364-Z1-M0#sh license right-to-use
slot License Name Type Period left
WS-C2960L-SM-Lanlite permanent Lifetime
I actually have LAN LITE on my other 2960L non smart ( WS-C2960L-24TS-LL) and i don't have any issues with the CLI configuration. Maybe the smart managed version is the issue. What other ways are there to get REP and IGMP configured if i can't do it from the CLI?
