configure NTP on cisco nexus 7k
hi there folks , i've got a problem getting ntp synch on my nexus
in my infrastructure 2 ASR connected to the nexus are serving  as ntp servers and 60 cat4500 are connected to the nexus as L2 switches
all my cat4500 seems to be sychronized ..below the show ntp status :
Clock is synchronized, stratum 5, reference is 10.32.253.22
nominal freq is 119.2092 Hz, actual freq is 119.2132 Hz, precision is 2**17
reference time is D9746D3C.AF6E2479 (14:46:52.685 METDST+1 Tue Aug 11 2015)
clock offset is -0.5251 msec, root delay is 5.83 msec
root dispersion is 7969.54 msec, peer dispersion is 1942.83 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is -0.000033184 s/s
system poll interval is 64, last update was 416 sec ago.
this is the nexus conf :
ip access-list copp-system-acl-ntp
  10 permit udp any any eq ntp
  20 permit udp any eq ntp any
ipv6 access-list copp-system-acl-ntp6
  match access-group name copp-system-acl-ntp
  match access-group name copp-system-acl-ntp6
ntp server 10.32.253.21 prefer use-vrf lombardia_mngt
ntp server 10.32.253.22 use-vrf lombardia_mngt
ntp source-interface  Vlan2550
ntp logging
now....i know very few about how NTP works .....
but it seems to me very strange
what a " show ntp status " shows ....
#sh ntp status
Distribution : Disabled
Last operational state: No session
any clue??
thx
6 Replies 6
Mark Malone
Hi make sure the feature is on -feature ntp- and its enabled -ntp enable-
Verification is different than ios check the show clock detail make you should see time source is ntp
and show ntp peers
also it should just work with ntp server x.x.x.x thats all i have set on my Nexus switches and ntp is working fine
Edit
This may help
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_2/nx-os/system_management/configuration/guide/sm_nx_os_cli/sm_3ntp.html#wp1071821
the ntp feature is active , but the output i get dont says "time source is NTP" ( see below)
VDC2# sh clock detail
12:29:24.054 GMT Wed Aug 19 2015
summer-time configuration:
timezone name: GMT
starts       : 5 sunday march at 03:00 hours
Ends         : 5 sunday october at 02:00 hours
Minute offset: 60
Martin Hruby
Hello Eugenio
What is the output of the show ntp peer-status command?
Best regards,
Martin
this is the output
VDC2# show ntp peer-status
Total peers : 2
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote               local                 st   poll   reach delay   vrf
*10.32.253.21           10.33.255.252           4   64     377   0.00264 lombardia_mngt
=10.32.253.22           10.33.255.252           4   64     377   0.00171 lombardia_mngt
That looks fine I wouldn't worry about the show clock detail not showing ntp it could be just the os version has different output
7kdis1# sh ntp peer-status
Total peers : 3
*172.21.17.110          0.0.0.0                 4   64     377   0.00066 management
=172.21.7.110           0.0.0.0                 5   64     377   0.00058 management
=172.21.7.111           0.0.0.0                 4   64     377   0.00070 management
Hello Eugenio
This is correct, your switch is synchronizing with 10.32.253.21.
On my switches with NX-OS 7.0(5)N1(1), the show clock detail command also doesn't show NTP as a time source.
Best regards,
Martin
