Configure Point-to-point VPN
Marcus Peck
Dear experts, I don't know where to start with this but here it goes:
I am implementing a point-to-point VPN tunnel from HQ to site office (which is server-less). Site-office clients get IPs from DHCP server in HQ. HQ has provision a DHCP range for site office and created a new VLAN for this range. Both routers are running on IOS C881-K9 image with basic routing (RIP). Below is the generic setup:
HQ (Servers + VLAN # + DHCP) -> Cisco 881 Router -> Internet Cloud <- Cisco 881 Router <- Cisco 2960
Clients from site office wants to access server information in HQ. What are the configurations to take note of? Should I use SDM?
Bilal Nawaz
Hello Marcus.
Im not an expert in VPN's but I know some basics. I've done a little lab and hope that it helps you out.
Some might think I've gone OTT but i've created a VPN and inside the VPN I have a GRE tunnel to pass though my LAN traffic. I'm not too comfortable with doing LAN to LAN VPN, but maybe some else could explain. Anyway I've acheived the same thing with this method.
Makes sense - and plus, it works. I also created an OSPF adjacency within the GRE tunnel so i can learn routes etc... but you can enable RIP here if you wanted. This may help when you have DHCP server in a different address range that is not local when you specify ip helper-address command.
R1#show run
Building configuration...
Current configuration : 1287 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
crypto isakmp policy 10
authentication pre-share
crypto isakmp key ciscokey address 100.0.0.2
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer 100.0.0.2
set transform-set myset
match address 101
interface Loopback1
ip address 10.0.0.1 255.255.255.255
interface Tunnel1
ip address 192.168.1.1 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 0
tunnel source Loopback1
tunnel destination 20.0.0.1
interface FastEthernet0/0
ip address 100.0.0.1 255.255.255.252
duplex auto
speed auto
crypto map myvpn
router ospf 1
log-adjacency-changes
ip forward-protocol nd
ip route 20.0.0.1 255.255.255.255 100.0.0.2
access-list 101 permit ip any any
R2#show run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
crypto isakmp key ciscokey address 100.0.0.1
set peer 100.0.0.1
match address 101
interface Loopback1
ip address 20.0.0.1 255.255.255.255
interface Tunnel1
ip address 192.168.1.2 255.255.255.252
ip ospf 1 area 0
tunnel destination 10.0.0.1
ip address 100.0.0.2 255.255.255.252
duplex auto
speed auto
crypto map myvpn
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
ip route 10.0.0.1 255.255.255.255 100.0.0.1
Verification of VPN
R1#show crypto sess
Crypto session current status
Interface: FastEthernet0/0
Session status: UP-ACTIVE
Peer: 100.0.0.2 port 500
  IKE SA: local 100.0.0.1/500 remote 100.0.0.2/500 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
        Active SAs: 2, origin: crypto map
R2#show crypto session
Peer: 100.0.0.1 port 500
  IKE SA: local 100.0.0.2/500 remote 100.0.0.1/500 Active
Verification of Tunnel interfaces and OSPF adjacency
R1#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
20.0.0.1          0   FULL/  -        00:00:34    192.168.1.2     Tunnel1
R2#show ip ospf neighbor
10.0.0.1          0   FULL/  -        00:00:31    192.168.1.1     Tunnel1
So I have my initial IPSEC VPN. And within that I have a GRE tunnel to provide my LAN to LAN connectivity. Therefor anything running within the VPN here is encrypted.
All you need to do here is make sure your routes are advertised, be it static routing or dynamic routing protocol via GRE tunnel interface.
i.e. ip route x.x.x.x x.x.x.x tunnel 1
or
router rip
version 2
network
network
Then you can advertise out your internal routes be it redistribution or some other method.
As long as your 881 router (in bold) knows the routes to internal network via tunnel interface it should be good.
Where your 881 router is connected to your 2960, your LAN interface should specify the ip helper address and specify the DHCP server IP. Please ensure you have routes towards this DHCP server.
Or even consider configuring a DHCP server on the 881 router local to your site office?
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Hello Marcus.
R1#show run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
set peer 100.0.0.2
match address 101
interface Loopback1
interface Tunnel1
ip ospf 1 area 0
duplex auto
speed auto
crypto map myvpn
router ospf 1
R2#show run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
set peer 100.0.0.1
match address 101
interface Loopback1
interface Tunnel1
ip ospf 1 area 0
duplex auto
speed auto
crypto map myvpn
no ip address
shutdown
duplex auto
speed auto
router ospf 1
Verification of VPN
R1#show crypto sess
or
router rip
version 2
network
network
Hope this helps.
