Configure replay-window for CTS manual?
navlrac
With plain macsec, you can apply an MKA policy with a replay window setting, however I haven't been able to find a way to configure the replay window size for macsec setup by "cts manual".
We need a replay window according to TAC to work around a separate issue, the default for CTS manual however is strict (window 0), and defining a new MKA policy as suggested won't have any effect.
Attempts to use the mka policy setting on an interface, configured for CTS, gives an error saying its incompatible.
so 'macsec replay-protection window-size' gives the error ? Can you post the full output of the error message ?
10 Replies 10
thanks, that seems to have worked.
I was previously stuck on mka policy and trying to apply that to the interface, which does give an error.
'macsec replay-protection window-size'  works, and now I have:
This looks OK?
SW10-DC1#show cts interface te1/0/1
Global Dot1x feature is Disabled
Interface TenGigabitEthernet1/0/1:
    CTS is enabled, mode:    MANUAL
    IFC state:               OPEN
    Interface Active for 00:01:33.903
    Authentication Status:   NOT APPLICABLE
        Peer identity:       "unknown"
        Peer's advertised capabilities: "sap"
    Authorization Status:    NOT APPLICABLE
    SAP Status:              SUCCEEDED
        Version:             2
        Configured pairwise ciphers:
            gcm-encrypt
        Replay protection:      enabled
        Replay protection mode: STRICT
        Selected cipher:        gcm-encrypt
*and*
SW10-DC1#show macsec interface te1/0/1
 MACsec is enabled
  Replay protect : enabled
  Replay window : 300
  Include SCI : yes
  Use ES Enable : no
  Use SCB Enable : no
  Admin Pt2Pt MAC : forceTrue(1)
  Pt2Pt MAC Operational : no
  Cipher : GCM-AES-128
  Confidentiality Offset : 0
Let hope that solves my actual issue of random CTS/Macsec link drops.
looks good to me, size is 300. Keep monitoring, hopefully that resolves the issue of random drops...
So unfortunately while the replay window seems setup, my underlying issue is not yet fixed. Trying a 15.2(4).E6 now instead of 15.2(6).E1 as it apparently has more fixes than the later, for 3560CX.
what is the underlying issue ? Not sure if you have already mentioned it in your original post ?
I had posted here about it separately, with no response. Its both simple and complex, here's a short-ish description:
Setup is 2x  3560CX  connecting 2 sites over dark fiber.
With no CTS/Macsec, link is stable and error free.
With CTS+Macsec (cts manual) - It works, however we get random link drops of around 205 seconds at a time. Happens between 1 and 5 times a day. No traffic passes, and rxL2AuthfailPkts just increments when its down. Then, the link re-establishes by itself.
I tried LACP with two fibers simplex, and both links go down - not at the same time & randomly (and a lot more frequently than single link configuration) - but LACP brings connectivity back after 30 seconds compared to the 200+ seconds. I see LACP errors in the logs.
TAC suggested possibly a known bug that I should turn on replay-window to work around, it didn't work for me, and now want to check another non-public bug, apparently fixed on the version I mentioned (possibly I require both the fix version and replay-window ?).
Also, weird things happen: during the drop, one of the 3560CX units (side A) stops responding to local pings / and SSH connections to it get dropped. It starts responding again 10-15 seconds before the link comes back. While the other side switch seems not to behave this way, I've not tested it much. If I shut/no shut the interface - I get the same behavior, I loose remote console to (side A), but (side B) console stays responsive - both on SSH, (I use a backup link between sites).
Getting highly frustrated and considering looking at other switch brands right now.
the only bug I could find that is even remotely related is the one below.
Can you post the configs of both switches ? Maybe I or somebody else can spot something...
CTS manual link does not come up
CSCus32213
Description
Symptom:
cts manual link does not come up between 3750 with 15.2(E) CCO image and any other macsec supported peer switch, unless "dot1x system-auth-control" global cli is configured on the 3750 switch.
Conditions:
CTS manual links on 3750 switch without configuring "dot1x system-auth-control" global configuration.
CTS manal link fails to come up, as the SAP negotiation fails to start due to the missing EAP ACL.
Workaround:
enabled the global "dot1x system-auth-control" CLI on 3750 switches.
Defect suspected: CSCvh10409
Current configuration : 4256 bytes
! Last configuration change at 21:23:55 AEST Thu May 31 2018 by xxx
! NVRAM config last updated at 21:24:33 AEST Thu May 31 2018 by xxx
version 15.2
no service pad
service timestamps debug datetime msec localtime
service sequence-numbers
hostname SWXXXXX
boot-start-marker
boot-end-marker
logging buffered 8200000
no logging console
enable secret 5 xxxxx
enable password xxxxx
username xxxxx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone AEST 10 0
clock summer-time AEDT recurring last Sun Oct 2:00 1 Sun Apr 3:00
switch 1 provision ws-c3560cx-8xpd-s
system mtu routing 1500
ip domain-name xxxxx
crypto pki trustpoint TP-self-signed-xxx
crypto pki certificate chain TP-self-signed-xxx
xxxxxxxxxxxxxxxxxxxxxx
        quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan dot1q tag native
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface TenGigabitEthernet1/0/7
 shutdown
interface TenGigabitEthernet1/0/8
 shutdown
interface TenGigabitEthernet1/0/1
 switchport trunk allowed vlan 5,7,20,21
 switchport trunk pruning vlan 2-4,6,8-19,22-1001
 switchport mode trunk
 macsec replay-protection window-size 300
 cts manual
  no propagate sgt
  sap pmk xxxxxxxxxxx mode-list gcm-encrypt
interface TenGigabitEthernet1/0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan20
 ip address 10.xx.xx.xx 255.255.255.0
ip forward-protocol nd
ip http server
ip http secure-server
ip ssh version 2
logging trap debugging
logging host 10.xx.xx.xx
no vstack
line con 0
line vty 0 4
 password xxxx
line vty 5 15
 password xxxx
ntp server 10.xx.xx.xx
end
configs look normal as far as I can tell.
The bug fix for the bug previously mentioned is to globally configure "dot1x system-auth-control". You might want to give that a try...
Any simple example configs showing dot1x system-auth-control?
Anyway more log trawling, this time on the peer has found the following at the exact time the link dropped:
925534: Jun  5 14:26:00.592: CTS SAP ev (Te1/0/1): EAPOL-Key message from 701F.53CD.2F0B.
925535: Jun  5 14:26:00.592: CTS SAP er (Te1/0/1): Old replay counter:
  received: 00000000 0000210E, expected: 00000000 0000210F.
925536: Jun  5 14:26:00.592: CTS-SAP err:  (Te1/0/1): Rcvd packet dropped due to old replay counter
925537: Jun  5 14:26:00.592: CTS SAP er (Te1/0/1): Received packet being dropped due to
  parsing/validation errors.
925538: Jun  5 14:26:04.570: CTS SAP er (Te1/0/1): Resend timer expired
No other occurrence of these messages in 10 hrs of debug log output.
