Configuring 1941 with 8 port EHWic Switch Module and onboard GE Ports
andrewrae
Can you configure a Cisco 1941 to use an 8 port EHWic module and the 2 onboard GE ports in a single LAN?
I've discovered you can't have the on GE ports associated with a VLan, and I'm when I've previously researched for a solution, bridging was mentioned but I cannot seem to get it to work (or completely understand it)
The reason I would like to use all 10 ports on for the LAN is becuase I have 10 devices I need to connect to the 1941?
Any help would be appreciated
Andrew
Reza Sharifi
Hi Andrew,
The onboard gig ports on the router are routed ports and not switch ports.  So, you can't assign the same subnet to 2 different interfaces.  You can use IRB to put both interfaces on the same subnet, but that is not very common and older technology and not sure if it is available on your router.
Even if you put theses interface on the same subnet, you can't add all the EHWIC ports to it.
Here is a link:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Hi Reza,
Thanks for your reply, and for the link. I did actually find that page during my search, but didn't look too closely at it.
I read through it more detail, and decided that I may need to run the PCs over 2 subnets to utilise all ports I have on the router.
I was following the guide on the link when I decided to try something - I created the bridge group, added both the onboard routed ports to that bridge group, then added a VLAN to the bridge group.
I then added the ports in the EHWIC to that VLAN (switchport access).
From the preliminary testing I've done so far, this seems to have solved my issue. Devices connected to either of online GE ports, or any of the EHWIC ports appear to be able to be on the same subnet and can talk to each other.
Below is a watered down version of the config I've got on the router.
version 15.1
service password-encryption
hostname R1
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.151-4.M4.bin
boot-end-marker
aaa session-id common
clock timezone EST 10 0
clock summer-time ESDT recurring last Sun Oct 2:00 last Sun Mar 2:00
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
vtp mode transparent
redundancy
vlan 8
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface ATM0/0/0
no ip address
ip virtual-reassembly in
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface GigabitEthernet0/1/0
switchport access vlan 8
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/1/4
no ip address
interface GigabitEthernet0/1/5
no ip address
interface GigabitEthernet0/1/6
no ip address
interface GigabitEthernet0/1/7
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan8
no ip address
bridge-group 1
interface Dialer1
ip address negotiated
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxxx@xxxxxx.xxx
ppp chap password xxxxxxxxxxx
ppp ipcp route default
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT_SOURCE interface Dialer1 overload
ip access-list extended NAT_SOURCE
permit ip 10.10.10.0 0.0.0.255 any
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^C
WARNING: Access to this system is limited to authorised users only.
^C
line con 0
logging synchronous
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input all
scheduler allocate 20000 1000
end
Do you see anything obviously wrong with this config?
Like I said, the testing of the local network side seemed promising. I just need to test and make sure all ports can access the internet next.
Thanks again for your help so far
Andrew
