Configuring 1DSU-T1 on Cisco 1720
scarabey_
I'm playing with a couple of Cisco 1720's and trying to make them work. Each of them has 1 WIC 1DSU-T1 (http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801a9184.html)
I reset both routers and configured onboard FastEthernet interfaces. However, I'm confused about these WIC's. They show up as Serial interfaces and I cannot bring them up.
I tried connecting them to each other and to a laptop via regular CAT5 cross-over cable, but all it shows is
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0 192.168.3.103 YES manual up down
Serial0 10.0.0.2 YES manual down down
(routers' configuration is provided below)
My questions are:
1. What am I doing wrong? Do I need to set up clock rate, etc for this "serial" interfaces?
2. Can I troubleshoot these 1DSU-T1 WIC's with a cross-over cable and a laptop at all? (Linux 2.6.8 with regular Ethernet interface)
Thanks in advance for any help!
5 Replies 5
scarabey_
P.S. Here's the routers' configuration:
test1#show interfaces serial 0
Serial0 is down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 10.0.0.1/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
test1#show running-config
Building configuration...
Current configuration : 601 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname test1
memory-size iomem 25
ip subnet-zero
interface Serial0
ip address 10.0.0.1 255.255.255.0
no fair-queue
interface FastEthernet0
ip address 192.168.2.104 255.255.255.0
speed auto
ip classless
ip http server
line con 0
login
line aux 0
line vty 0 4
login
end
test2#show interfaces serial 0
Internet address is 10.0.0.2/24
Last clearing of "show interface" counters 00:15:29
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 output errors, 0 collisions, 6 interface resets
test2# show running-config
Current configuration:
version 12.1
hostname test2
ip subnet-zero
interface Serial0
ip address 10.0.0.2 255.255.255.0
no fair-queue
ip address 192.168.3.103 255.255.255.0
speed auto
ip classless
ip http server
line con 0
login
transport input none
line aux 0
line vty 0 4
login
no scheduler allocate
end
The biggest problem is your crossover cable. An Ethernet crossover will cross 1, 2 and 3, 6 but a T1 serial crossover will cross 1, 2 and 4, 5. You can not use standard Ethernet crossover to connect serial interfaces.
Once you get a correct crossover cable you will also need to configure one of the routers for clocking internal and to configure a clock rate.
Rick
Rick
Thank you Rick!
You are quite welcome. Thank you for the rating.
Rick
Rick
The correct command to see the status of the physical serial port is 'show controller serial'.
Also, the status of the T1 DSU is seen with the command 'show service-module'.
Please note that a Cat5 patch cable may short-out one or both of the CSU's if used to connect back-to-back.
Be sure to *only* use a cable with pins 1,2,4 and 5 connected. *DO NOT* cross-connect *any* other pins!!! A T1 should specifically *not* be grounded on pins 3 or 6, particularly between 2 cross-connected routers.
