configuring 802.1q on 2600's ethernet interface
worldcalltel
Is 802.1q on 2620's ethernet interface possible. coz as far as im concerned it only works on fast ethernet interface..i dont have any fast ethernet on my 2600 router..i just want to make sure on this. coz i tried to configure my 2600, and there is a command for 802.1q..so i configured my trunking and it does not work at all. or is there something wrong with my setup..anyway, here is my config:
2900:
interface FastEthernet0/1
interface FastEthernet0/2
switchport access vlan 2
spanning-tree portfast
interface FastEthernet0/3
switchport access vlan 3
2600:
interface Ethernet0/0
description Connection to LAN
no ip address
ip accounting output-packets
half-duplex
interface Ethernet0/0.1
description TO-GACI
encapsulation dot1Q 1 native
ip address 10.10.10.254 255.255.255.192
interface Ethernet0/0.2
description GPS
encapsulation dot1Q 2
ip address 192.168.111.1 255.255.255.0
interface Ethernet0/0.3
description TO-ZHAPA
encapsulation dot1Q 3
ip address 192.168.112.1 255.255.255.0
kerek
Level 4
Level 4
Vlan trunking is supported only on FE, GE and 10GE interfaces.
mohammedmahmoud
Level 11
Level 11
Despite it is said in the books that it is not supported on Ethernet interfaces (only FE and GE), practically it works out on Ethernet, however there is a possibility that you have come across Caveat CSCds42715, in which the 802.1Q native VLAN keyword does not function properly, please check the status and a brief description of the bug by using the Bug Toolkit (registered customers only) and entering the bug ID CSCds42715.
HTH,
Mohammed Mahmoud.
