Configuring ATM on ISR4k
jehooper
I am attempting to convert a configuration from 3845 to a new 4351, but seem to be running into some trouble. I cannot determine if there is a direct replacement for the AIM-ATM module for the ISR4K. The new hardware I am using is a ISR4351-SEC/K9 with a NIM-2MFT-T1/E1.
Currently I do not have the option to configure the T1 controller on the 4351 as ATM. Do I need additional hardware, or is there a configuration that I am missing?
Below are the configs from the 3845,
CISCO3845
AIM-ATM
VWIC2-2MFT-T1/E1
controller T1 0/0/1
mode atm aim 0
fdl both
cablelength long 0db
interface ATM0/0/1
description AT&T "
no ip address
no scrambling-payload
ima-group 3
no atm ilmi-keepalive
no atm enable-ilmi-trap
Reza Sharifi
I don't think ATM is supported on the 4000 series.
See this link for supported interfaces and modules
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#ethernet-switch
Reza Sharifi
