Configuring C2960 for NTP
bobby818
Hardware - C2960
IOS - 12.2(25)
I am examining a requirement to configure C2960 as below
NTP internet sources > C2960 > Domain Controllers > other devices and servers
In theory what I am trying to achieve is to synchronize C2960 with multiple NTP internet sources which then would act as server and serve as NTP source to all windows domain controllers. Rest of the environment (other servers/host PC and switches) will synchronise with windows domain controllers to seek time.
Please could you advise how this can be achieved?
On the C2960 there is SVI available and routed for management access.
Following are options under interface Vlan
C2960(config-if)#ntp ?
broadcast Configure NTP broadcast service
disable   Disable NTP
Below on global config mode
C2960(config)#ntp ?
access-group       Control NTP access
authenticate       Authenticate time sources
authentication-key Authentication key for trusted time sources
broadcastdelay     Estimated round-trip delay
clock-period       Length of hardware clock tick
logging             Enable NTP message logging
max-associations   Set maximum number of associations
peer               Configure NTP peer
server             Configure NTP server
source             Configure interface for source address
trusted-key         Key numbers for trusted time sources
Thank you
Ta
Reza Sharifi
Here is the config guide for the 2900 series to follow and configure your switch as an NTP client.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swadmin.html#wp1053923
Is this what you looking for?
Reza Sharifi
Thanks Reza, I will follow this document and try configuring up NTP.
Cheers
Ta
Sorry it is confusing, should the switch be configured as peer or server?
Because I need the switch to synchronize with internet source and then act as source back to internal networks only.
Thank you
Ta
yes, it should be configured as peer
