How to communicate between layer2 switches in a intervlan?
Hereby i attached my packet tracer of my disscussion.
i cant able to communicate or telnet between the layer2 switches from the respected vlan ports.
Pls help my need.
advance thanks for ur solution.
Thanks and regards, Chandhuru.M
InayathUlla Sharieff
Chandhuru,
I made some changes and it working now.
Kindly configure the following and you should be able to ping and telnet to the switches between the layer 2 switches.
1- Remove the Vlan 1 configuration and configure vlan 10 and 20 respectively on the Core switch.
3560:
GigabitEthernet0/2     unassigned      YES unset  down                  down
Vlan1                  192.168.1.1     YES manual up                    up
Vlan10                 192.168.10.1    YES manual up                    up
Vlan20                 192.168.20.1    YES manual up                    up
b- Switch 2960- A
Vlan10                 192.168.10.2    YES manual up                    up
Switch#
c- Switch 2960 -B
Vlan10                 192.168.20.2    YES manual up                    up
Switch#
Make sure the port is trunk and its negotiated.(Switchport mode trunk, Switchport trunk encapsulation dot1q,)
Telnet configuration:
Switch 1 & Switch 2
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#username cisco password cisco
Switch(config)#enab
Switch(config)#enable se
Switch(config)#enable secret cisco
Switch(config)#line vty 0 4
Switch(config-line)#lo
Switch(config-line)#logi
Switch(config-line)#login local
Switch(config-line)#pas
Switch(config-line)#password cisco
Switch(config-line)#end
Switch#
Switch#telnet 192.168.20.2
Trying 192.168.20.2 ...Open
User Access Verification
Username:cisco
Password:
Switch>en
Password:
Switch#exit
I just tested and its working fine now.
Inayath
******plz rate all usefull posts.**********
Chandhuru,
3560:
b- Switch 2960- A
Switch#
c- Switch 2960 -B
Switch#
Switch 1 & Switch 2
Switch#conf t
Switch(config)#enab
Switch#
Username:cisco
Password:
Switch>en
Password:
Switch#exit
Inayath
Dear InayathUlla Sharieff:
     Really thanks for ur needful reply.
    I got the output.
     Now its working fine. Hereby i attached PT also for ur clarification.
     Once again real thanks from me.
with regards,
Chandhuru.M
You are welcome Chandhuru.
