Configuring Etherchannel
navnsing
Community Member
I have two Fast ethernet interfaces on a WS-C2924M-XL acting as trunk ports and allowing multiple VLANs. I want to configure an etherchannel on these ports, but iam unable to do so.
Appreciate your help on this.
Navneet
Amit Singh
Navneet,
You have to use "port-group" command under the interface configuration mode on these old switches. Which device is there at the other end?
Please find the link below for ether-cahnnel configurations:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc3/sc/swgports.htm#xtocid13
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12119ea1/2950scg/swethchl.htm
HTH,Please rate if it does.
-amit singh
