Configuring ISP failover ASA 5505
daniel2907
I am trying to configure ISP failover on my ASA, here is the commands I have used so far
ASA(config)# sla monitor 10
ASA(config-sla-monitor)# type echo protocol ipicmpEcho 8.8.8.8 interface outside
ASA(config-sla-monitor)# num-packets 3
ASA(config-sla-monitor)# timeout 1000
ASA(config)# sla monitor scheldule 10 life forever start-time now
ASA(config)# route outside 0.0 87.82.x.x
ASA(config)# route backup 0.0 82.109.x.x
ASA(config)# track 1 rtr 10 reachability
ASA(config)# Nat (inside,outside) source static any any destination static NETWORK_OBJ_172.16.1.0_24 no-proxy-arp route-lookup
ASA(config)# Nat (inside,backup) source static any any destination static NETWORK_OBJ_172.16.1.0_24 no-proxy-arp route-lookup
After inputting these commands I can ping from my laptop to 8.8.8.8 with 100% success rate from both main ISP and backup ISP but cannot access internet, why is this? I am assuming this is NAT related? If so what changes need to be made (static)?
(P.S I am applying these commands in a working enviroment)
Thanks in advance!
daniel2907
Sorry I meant I can ping from the firewall to 8.8.8.8 from both my main ISP and my backup not from my laptop***
Two things have to be setup:
1) the backup route should be configured with a higher AD:
ASA(config)# route backup 0 0 82.109.x.x 200
Was the 0.0 a typo? If not the command was not acceppted.
2) your NAT statement is also syntactically incorrect. And you probably need a dynamic NAT to both providers.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Hi Karsten,
1) Sorry I forgot to add that in;
ASA(config)# route outside 82.109.x.x 1
ASA(config)# route backup 82.109.x.x 254
2) It would not suprise me as I am new to programming cisco devices/teaching myself however, it has been running on that NAT statment for a few months now, what error do you see?
I thought as much, I will try and configure a dynamic NAT as I have not done this before and see if that solves the problem. What procedure shall i follow (create network object, create NAT rules etc)?
thanks
