configuring site-site vpn configuration between cisco router 1941 and 4300 model
raffi.shaik
Hi Mates,
I need to configured site to site VPN between 1941 router and 4300 router.
Please help on is VPN can support those both models or need to purchase new model router.
Rafi
18 Replies 18
with the right license (SEC) this shouldn't be a problem. Do you already have the routers ? If so, post the configs so we can fill in the necessary bits and pieces...
Hi georg,
Thanks for reply. please find attached config file.
Rafi
Hi ,
Any help.
Rafi
Sorry for the delay, I'll have a look...
Thank you for your time.
there are different ways to do this. Below is a sample configuration for a static VTI (which is easier to configure than crypto maps). See if you can get this to work:
1941
ip dhcp excluded-address 192.168.10.1
ip dhcp pool LAN1
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
lease 3
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key ciscovpn address 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set TRANSFORM_SET esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile VTI
set transform-set TRANSFORM_SET
interface Tunnel0
ip address 172.16.1.1 255.255.255.0
tunnel source 10.10.10.1
tunnel mode ipsec ipv4
tunnel destination 10.10.10.2
tunnel protection ipsec profile VTI
interface GigabitEthernet0/0
description LAN1
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description to 4331
ip address 10.10.10.1 255.255.255.252
duplex auto
speed auto
media-type rj45
router eigrp 1
network 0.0.0.0
4331
ip dhcp excluded-address 192.168.20.1
ip dhcp pool LAN2
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
lease 3
encr aes
group 2
mode tunnel
interface Tunnel0
ip address 172.16.1.2 255.255.255.0
tunnel source 10.10.10.2
tunnel destination 10.10.10.1
description LAN2
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
media-type rj45
description to 1941
ip address 10.10.10.2 255.255.255.252
duplex auto
speed auto
media-type rj45
router eigrp 1
network 0.0.0.0
Hi ,
Thanks for above.
Sorry, I forgot to mentioned there is point to point connection between two routers live.
On 1941 router we need to add 3rd interface VPN connection.
Is this router compatible to add the interface and is interface card available on market present.
you don't need a different physical interface, you can use the existing point to point connection and configure the tunnel as an overlay...
Hi Georg,
I have one more question.
If point to point link down , then VPN also get down right.
Because there is no internet connection on VPN.
Rafi
exactly, of the point to point goes down, the VPN goes down as well.
Can you post the output of 'show ver' ?
Hi Georg,
Our requirement is when point to point link down then VPN will play backup line role.
Please advise based on this .
Kindly find the show ver output
Rafi
an IP SLA would probably work best. I'll have a look and send a config over...
Thanks for your valuable time. i m waiting.
here are the configs. This is assuming that you are using different physical interfaces for the point to point link and the VPN backup link.
You need to use static routes instead of EIGRP. Also, I have added an IP SLA on both routers to automate the backup.
1941
version 15.6
hostname 1941
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
ip dhcp pool LAN1
lease 3
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp log mismatch duplex
track 1 ip sla 1 reachability
ip tcp synwait-time 5
encr aes
group 2
crypto ipsec transform-set TS esp-3des esp-sha-hmac
mode tunnel
set transform-set TS
interface Tunnel0
description LAN Interface
duplex auto
speed auto
media-type rj45
description Primary Point-toPoint to 4331
ip address 100.100.100.1 255.255.255.252
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
description Backup VPN to 4331
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 100.100.100.2 track 1
ip route 0.0.0.0 0.0.0.0 Tunnel0 200
ip sla auto discovery
ip sla 1
icmp-echo 100.100.100.2 source-interface GigabitEthernet0/1
ip sla schedule 1 life forever start-time now
4331
version 15.6
hostname 4331
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no mmi pvc
ip dhcp pool LAN2
lease 3
no ip domain lookup
ip cef
no ipv6 cef
redundancy
encr aes
group 2
mode tunnel
interface Tunnel0
duplex auto
speed auto
media-type rj45
description Primary Point-to-Point Link to 1941
ip address 100.100.100.2 255.255.255.252
duplex auto
speed auto
media-type rj45
description Backup VPN to 1941
duplex auto
speed auto
media-type rj45
no ip http server
ip route 0.0.0.0 0.0.0.0 100.100.100.1 track 1
ip sla 1
icmp-echo 100.100.100.1 source-interface GigabitEthernet0/1
